- 10 Apr 2006
- North West
Tried installing 3DMark06 from the futuremark website and some DLL error occurs and won't let me run it :/
me said:PLEASE READ THIS CAREFULLY:
rather than try and sort the results manually, i've created a simple webform here. you must submit your score this way to get on the list.
I tried last night but the site wouldnt load!
Works now, submitted
If I submit a new one will it auto update if I use same username ?
me in the opening post said:the database allows one record per user. if you need to edit any details, such as hardware or clockspeeds, or you just have a higher score to submit, then use the form again and it will overwrite your last result.
He'll delete the old result and replace it with the new one most likely.
