Upgraded from my old 939 system to a Core 2 Duo system over Christmas. Looking over my old pictures shows just how much my systems internals have changed over such a small period of time but with the exception of this Akasa Mirage case which looks like it will outlive everything else that is currently inside it.
My system at the start of 2007:
Minor tidy up signalling the removal of IDE from my system:
Q3? Upgrade:
And finally my current build:
I got a bit fed of having to remove the PSU everytime i wanted to remove my tray since I was hiding some fan cables under it, so I decided to drill a hole by the side of it to thread them through instead.
I was considering getting the replacement side panel that has a fan built into it to improve cooling a bit more but it seems OcUK has stopped stocking them now.
Nice setup.. I was looking to buy a couple of the Akasa fanned side panels from them in the new year, hopefully some might come back in stock soon..
would have to clean the filters, may rig doesnt get that hot, and its next to a radiator
