After waiting for eternity for the other thread in the cpu section to get a database going I thought I'd have a go at making one myself.
You must include :
CPU
Revison
FPO#
Clockspeed
Vcore (under load in windows)
Vid (core temp)
Motherboard
Cooling
Thermal paste used
CPU Temp
Your CPU MUST be 8+hours stable for entry to be made.
Also include a screenshot showing :
P95 25.2 or above fully loaded on all 4 cores(running small fft's) (ensure to show the time started in the first box).
CPU-z 1.41
Coretemp or everest for temp validation
If your post dosn't include the above then it won't be entered
Please no arguments regarding whats stable and what isn't - I'll make a suicide/PI thread later for those who hate prime. 8 Hours is widely accepted as an indication of a stable cpu - if you don't agree don't bother posting
Me
w3bbo
Devious
Fornowagain
Jokester
weescott
Big wayne
etc... all use small fft when finding the max overclocks of our cpu's.
It's widely understood and accepted in the overclocking community.
Nice screenie there mate.
Glad to see some solid results.![]()
----BOOM---- HEADSHOT!
Testing a cpu clock is done using small FFT as it stresses the cpu more than blend.
Small FFT maximum heat maximum stress.
At that conservative clock Blend is not the ideal test.
You test the cpu stability before the systems, and the temps would much higher on Prime95 and small ftts,enough to fail.
Period.
However I still use small ffts to generate maximum heat and test the cpu in isolation. Even prime systems can be far from stable, so no its not the be all and end all, but its a start. Prime95 and small ffts will push the cpu harder than most.
pffft, granted if a overclock is unstable say one crash a day, then you know to reduce it down. However if under normal heavy usage it never crashes it can be seen as stable. You don't need to do 8+ hours tests to insure it's stable. For a server you won't clock it so you can be 100% sure it's stable.
Wrong!
I dont use small fft's for finding the max overclock .
As I have said before.
If your pc cannot calculate data without error there is something not correct with your rig.
Gaming stable,encoding stable just don't cut it.
