Oh no, don't touch Asus software. There is a speedfan beta out that knockks 5c off the temp...but I don't think thats right either.
Lol, so basically what you are saying is that theres nothing reliable atm?
... which is a bit weird if ya aask me... unless the TRUE is actually that good
What is your problem? It was my choice, my money and i really do not need your blessing. You just don't seem to be able to keep your mouth shut and let other people do what they want to do. You always have to have a dig. A 5 ghz quad would have been no use to me because as i told you before i have nothing that makes use of the four cores. I actually sold the quad for more than i paid for it anyway.
I have had this Wolfdale for a total of 7 hours 43 minutes, only 6 and a half hours of which it has been in my rig. Most of that time has been spent running prime @4ghz with all voltages and settings on stock. That is damn good. I am still finding my way around the P5E's bios and experimenting with settings, some of which i have no idea what they do. Add to that the terrible vdroop and it's early days yet. It took ages to get the most out of the quad. There were times that i was stuck on 3ghz then i tried something different and got it to 3.2ghz and so on. No doubt it will be the same with this one.
***Edit***New bios just released for the P5E, ver 601 and it's up on the Asus ftp. Someone is testing it over at XS so hopefully this may fix a few things.
I actually have to defend easy here, I don't think he was being condecending "this time".
That's the problem with forums, You have no context or emotion for what you read/type.
I read it that easy prefers quad over duals for what he uses his PC for compared to you/I who mostly game where a higher clocked dual core is more benificial that having a lower clocked quad core.
The problem isn't with Core Temp weescott as it's taking the reading directly from the diode in the CPU. It's looking like the diode's are either calibrated by Intel incorrectly, or they're just plain duff.Core temp doesn't read the temperature of Wolfdale CPU's properly. It over reads by a fair bit. Its fine.
You're right about SpeedFan. It's basing its reading on the max Tjunction temps for the Wolfdale's to be 100c, and not the correct value of 105; that's why it's showing temps 5c lower.Oh no, don't touch Asus software. There is a speedfan beta out that knockks 5c off the temp...but I don't think thats right either.
ok regardless of the temp settings i went ahead and tried to do some stressing at 3.6 GHz last night to see if it was stable.. heres what i got..
speedfan only went up to 35oC but core temp did raise to 42 ish, i think i put the voltage to auto on the mobo and thats what it came up with.
but the other thing is the mobo temp didnt change atall?! 25 constant? that cant be right, cos i put my hand on the northbridge HS and it was warmer than it was before... hummm but still why the failing
also tried again now just on stock everything and it failed after 12 mins?! wwhats going on![]()
Ah ha!! Another P5E clocker. Are you on the 502 bios? I think it's a board problem as i am having a hard time getting stability as well.
put it back to stock Hz and auto volts, hope this issus is resolved soon.... are you getting messed up temps too?yep i am indeed on the 502.... it seems to run games and everythign fine at the oc speed... but stillput it back to stock Hz and auto volts, hope this issus is resolved soon.... are you getting messed up temps too?
whats the highest fsb hit so far on these?
Where are you getting the temps from? Asus Probe? I don't think it's right as it constantly says the MB is at 25 degrees. Never goes up or down. I might try the latest version that was released 10-1-08. I don't think core temp reads the Wolfies correctly either. My most stable (and easiest) clock so far was when i left everything at auto and just raised the fsb to 422. That was an easy and very stable 4Ghz. Playing with the other settings just led to unstability. There is a new bios, 601, that was released yesterday but i don't really want to give it a go without any feedback. Some of the guys at XS are playing with it.
no good.
i have the same ram as you also
and using my antec 900 and TRUE HSF with s-flex 1600 for cooling hehe
oooo u got stable at 4GHz easy? could ya send me the bios settings ya used for that please? i noticed theres quite a vdrop on these boards too, tried to set it to 1.192 and it dropped to like 1.12no good.
but if you could tell me your settings pretty pleaseeei have the same ram as you also
