Caporegime
 - 8 Jul 2003
 - In a house
Personally for £460 the GTX280
They gona be that cheap then you rekon.
They gona be that cheap then you rekon.![]()
Intel Extreme Graphics \o/And the winner is ...........................
They could sell for £2k and you will get some idiot buy them as long as they are faster than Ati.
Or even if they were slower.Sadly, this is true.![]()
Shader power isn't everything, it seems nVidia is coming out with a much more balanced card (much more fillrate in everything), whereas AMD are going for lots of shader muscle and bandwidth. AMD's game plan could well be to sell more based on upcoming GPGPU applications, with far more raw shader power.
Edit: Just to clarify, what I'm saying is AMD aren't at all lying about how much shader power they have, it's just nowhere near as important as people are making it out to be. I think this is best illustrated with the 9600 GT, which has little over half the shader power the 8800 GT does, but isn't far behind it at all.
With PCI Express slot providing 75 watts of juice and the motherboard another 75 watts, there is a theoretical supply of up to 225 watts. That is quite a jump in the sub-$300 segment and it makes you wonder what the reasons may be, but we are certain that overclockers won't mind. One of key limitations for the extreme overclocking of the previous generation parts was the fact that the cards (3850, 3870, 8800GT, 8800GTS512) had only one power connector.
And the reason why ATI was so popular with overclockers was the fact that you could tell the motherboard to supply 150 watts, and ATI's 3870 would eat 150 watts from the motherboard (total: 75 watts + 150 watts = 225W). With two power connectors in place for the 4850 and 4870, overclockers do not need any hacks to get access to 225 watts. In fact, the 4870 will top out at 300 watts (150 watts from the motherboard, 75+75W from connectors). The 9800GT will be restricted to 225 watts (75 watts from the motherboard).
and how does one power connector limit overclocking? lmao
Have these benchmarks been posted? for 3dmark and crysis?
http://xfastest.com/viewthread.php?tid=10925&extra=&page=1
If true then only 480 shaders
And what is the point running crymark at 800 x 600![]()
