- 8 Mar 2007
- Swindon, Wiltshire
At £300+ I'm surprised they started moving let alone crawled
4850's in crossfire just rock for the performance you get for the outlay.
That's expected to be more expensive, $230ish vs $199, which, fair enough isnt huge but this is the segment where every $/£ counts. It only runs 10% quicker than a 4850 a difference you can OC your way out of. ATi also has that bonous of onboard sound, to edge the pros and cons in it's favour.
Martyn
They (OcUK) accidentally posted the prices briefly, the cheapest was £211 for the 4870. Even the 4850 512mb is a massive improvement from an X1800 XT.How much more £ do you reckon the 4870 will be?
I reckon either of these should be an good boost from the aging x1800xt I'm using right now!
Wonder what the hit is if running a P45 mobo with 2 x 8 pci-e lanes and these cards?
Just what happened to me. lol.I don't think it would be worthwhile. I can play Bioshock quite happily with my current card in the x16 pci-e slot. However, when I was messing around tidying the case up, I tried it in a lower slot forcing the card to run at x8. At first I didn't realise but when I fired up Bioshock again it was juddering and lagging all over the place. As soon as I put the card back in the correct slot it was smooth as butter.
So I don't think it would be worth while personally, although I have no figures to back this up with.Just what happened to me. lol.
A 4850 runs fine on a 16x pci-e 1.0 slot and hence will run fine at 8x pci-e 2.0 slot - same bandwidth.
Onboard sound = always rubbish
10% quicker = actually quite a lot (obviously the 9800+ will clock too)...
Its a wash really going by the reviews\previws...both seem good.
Err your board is a p35 no?
Easyrider was refering to a p45 board.
Your lower slot on the p35 board would be running at 4x, not 8x and more importantly it is pci-e 1.0
The p45 boards are pci-e 2 so double the bandwidth. Ie running at 8c on a pci-e 2 board is the same as you running at 16x in your slot 1.
