Suppose it does if you have to shell out for another mobo as well as the 2x cards.
Any reason Easy?
...I have better results with two 4850 running in xfire on a p35 board and hence at 16x and 4x or 8x and 2x in pci-e 2 bandwidth terms...
Very true. If you were building from new what would you currently plump for?
I don't understand this, are you saying a 16 x pci-e slot (1.0) is the same bandwidth as an 8 x pci-e (2.0) slot ?, surely that not right ?
Show me links for that![]()
http://www.anandtech.com/video/showdoc.aspx?i=3338&p=14
Crisis 8800GT SLi wins by small margin
COD 4 4850 CF wins
Quake Wars, 8800GT Sli wins
Assasins Creed 8800GT Sli wins
Oblivion 4850 CF wins
the Witcher 8800GT Sli wins
Bioshock 8800GT Sli wins
so there u go...
ah but my point is that the 8800GT can be had cheaper than 2x 4850...and provides nearly on par results...
Yes is is. pci-e is double the bandwidth of pci-e 1.0 or 1.1 slots
Look at wiki or google it if you don't beleive me.
Hence my beleif that it's either a chipset or bios problem with the p45 boards as essentially they are the same as two 16x pci-e slots and I haven't seen/heard any problems with that.
Pci-e 3 next year is set to double the pci-e bandwidth again ie 16 x pcie-1 = 8 x pcie-2 = 4 x pcie-3.
Then go for it
8800GT SLI OR 4850 XFIRE
The mobo dictates the choice.
