well I havent told mine.... "look dear the £40 case I ordered has arrived"![]()
I know what you mean, "my 260GTX was only £100"
hope she don't read this......
I soooo need that Omega Top and Side pannel for my Eclipse...
Not keen on the front of the Omega at all, but I love my Eclipse.
I'm sure you could contact akasa and get both for very little. They can replace any part of the cases.
*just got my second mirage front from them this fine morn and its perfect*
Is there fixings fon the top panel to have 120mm fans fitted...
Hope your replacement is A1... You starting your build soon, just asking as you have stated you are boxing it back up.
Nice build going on there, very tidy.Couple of shots of the mirage build i'm doing for my mate.
snip
Used to have a uv theme in my eclipse. psu sleeved in green, and blue sata/ide cables and green rear fan. Think ill go all black soon. got a pile of black cables from my old evga 680i that were never used.Thanks just needs the GPU, sound card and sata cables plugging in. going to do orange UV sata cables with blue led fans
Hi Mark,
Thank you for your mail.
The aluminium panels from OMEGA would fit the ECLIPSE case but there would
be problem with power/reset buttons and the I/O ports located on the side of
the OMEGA front panel; you would required the whole front with all the
cables and PCB.
At the moment we don't have any spare panels specific for the OMEGA case but
you may check again with us in couple of months.
Kind Regards,
Jerry
Akasa (Europe) Ltd
Reply to me asking if it is possible to purchase the side and top pannel from the omega, and if it would fit the Eclipse OK.
