after reading this thread i was inspired to get this case for my new rig and im so glad i did
I am installing a P5Q-DLX either tonight or tomorrow so will get back to you!
I installed my P5Q-E and some of the USB ports and the eSATA port are inaccessible. I put it straight onto the stand offs which are already in the case too and the board is still too high or the back plate is cut wrongly, so Overclockers are kindly sending me another P5Q-E back plate to see if that allows me to use the USB ports or atleast I have a spare one to modify.
My motherboard is the standard P5Q. It fits fine into this case with the built in stand-offs and in line with the back plate.
What were you doing wrong, as I maybe doing the same, but all I have done is put the Motherboard on the built in stand offs and screw it in.
You're doing it right, I did it wrong from the beginning. That's all I'm gonna say![]()
