And I have a question about this case - anyone with HDD's installed in the lower chamber, is it possible to install a 120mm fan on the HDD side of the lower chamber?
Anyone?
Do you mean to fit a fan in front of the HDD (i.e. up against the front of the case)? That's not possible without modding the case.
No, fit a fan after the HDD's, but before the partition, if you see what I mean?
It will fit but you need a right angled SATA cable to make sure the cable doesn't touch the fan - or you could screw a grill infront of the fan to stop it happening.
The DVD drive definitely clicks into place once it's home. You shouldn't be able to slide it out again without squeezing those tabs at the front. It shouldn't take any real force to push home, though - maybe the back of the drive is caught up on something?
You should be able to adjust how far out the drive sits, as you've got a choice of 3 holes on the rails at the front of the drive, and a 'slot' for the rear screws.
Hornett; are you hiding your sata connectors in the PSU chamber for your hard drives? Have you thought about putting the HDD down there at all?
Is it possible to replace the 3 screws that attach the right hand panel with thumbscrews? and if it is, where can one obtain the thumbscrews?
Well guys, finaly got the case! Got it from a mate for £35.. was a bit shabby but i spent two days cleaning it out, and putting everything back together. Phone pics i'm afraid
That looks awesome mate, an absolute steal for £35, it looks great condition too![]()
