I got my P182 today, along with all the other bits.
Here are some pictures...
[snippage]
Hope you like![]()
Newbie question, but important!
I have just received my Antex 182 today, with a Zalman 850 PSU.
Important question: should the fan on the PSU be at the top or the bottom? I assume bottom, because of the orientation of the text on the PSU case.
Secondly, does anyone know if the PSU fan is an intake or outflow?
Thirdly, I have had to remove the bottom fan to fit it in. Is this likely to cause any problems?
I have a P45 motherboard, 4870 graphics card, single 1TB Samsung F1 and a Blu-ray drive, so not particularly full.
One last thing - anyone suggest whether I ought to mount the HD in the top or bottom compartment (I will remove the other one).
Thanks for your help, whoever you are!
John
John
I found it best to have the PSU with the fan pointing down so that the main power cable could route up the back of the case.should the fan on the PSU be at the top or the bottom? I assume bottom, because of the orientation of the text on the PSU case.
Normally a PSU fan would sucks air in through the big main fan and out through the back.Secondly, does anyone know if the PSU fan is an intake or outflow?
DO you mean remove it and not put it back or? Quite a few peeps have perm removed it to fit huge PSU's and not had any issues I heard of. I have mine installed and routed the cables carefully. The PSU never gets hot now and I'm hoping that fan will help the PSU last 3-5 years!Thirdly, I have had to remove the bottom fan to fit it in. Is this likely to cause any problems?
I mounted two 3.5" hard disks in the lower disk tray and removed the upper disk tray to give more space and slightly better airflow!One last thing - anyone suggest whether I ought to mount the HD in the top or bottom compartment (I will remove the other one).
