Hmm I'm going to buy an Intel Nic (better check the list now you have said that) and also check the HP raid controller card.
I'm thinking of getting one of these to use as a cheap workstation. Can anyone recommend a basic PCI-e graphics card to put in and a pci sound card. I have an aversion to onboard graphics and I like to have music blasting from my pc while I work
Cheers
Mal
) and also watch out for the CPU heatsink it's very very close to the only PCI-E slot, someone also warned me about the psu in terms of output for high power cards,
The Xeon ML110 G5 are same price as the AMD Ml115 G5's now
Can anyone confirm if it supports RAID 5 before I buy?
Cheers
Zaf,
in
trust
I wanted one of those over the AMD from the start!
just contacted the place doing the 115 for £93+vat and they offered to do it for the same
Ordered my 110 Last night but shipping is split with my bro so not to bad I guessMine is now happily running ESX3i Windows 2008 x64 and had Xen and Virtual Iron installed at various points as well.
Is that on a HP ML110 G5 with no extra hardware, just the straight specs?
