On macstosell it says my MBP is worth around £860....2.4 C2D
Thinking of going for the top end macbook.
Do you think its a good idea going from the pro to the macbook?
Im not fussed about the screen size all i want o be able to do is connect my 30" monitor which they all can do now even the air.
Do you think this is a good idea or not?...Anyone else thinking of doing the same?
Just like with the last iteration, the only only substantive difference between the MB/MBP is the graphics.
Now that there's so little between the machines physically, it just makes that point stand out more.
