If my budget hadnt got me an EP3, id have definately bought a DC2...
The DC2 is MILES better than an EP3. The EP3 is a chav-chariot, like most warm hatchbacks, whereas the DC2 is a proper, hardcore enthusiasts driving machine.
[TW]Fox;12785493 said:The DC2 is MILES better than an EP3. The EP3 is a chav-chariot, like most warm hatchbacks, whereas the DC2 is a proper, hardcore enthusiasts driving machine.
There's a blue one I see around and it looks awesome. Only 200bhp though...and not very tunable?![]()
I've driven plenty diesels in anger and thats not a great comparison at all, as i said i doubt they would put one in a dc2 as an alternative to a vtec somehow, i was thinking more along the lines of a slightly larger petrol engine.
Oh thanks for the sweeping generalisation Mr 40 something businessman.
You generally have a heavier engine though, not ideal for a car pointyness. But then comparing a recent 2.0 to a 15year old 1.8 will probably favour the 2.0. The fact they are similar says lots about the B18C6.
generally yes but then a B series can provide more displacement with little difference in weight, so thats not a given. The engine in question was a 3s-ge with vvti, released in 97 so yes a couple years after, but vvti has been around since 95 in the toyota. Such engines get little notice because of the chassis they were put in.
Oh right I was thinking Clio 197.
So your car has its own variable valve timing aswell? And suprisingly more torque from its 200cc larger engine?
Im failing to see your point here. The irony is that if you bore a B18 up to 2.0 you generally get more of an improvement than the displacement would suggest as the ports are marginally oversized from the factory.
i didnt really have a point i just suggested that they could have acheived a similar power level and overall experience without using vtec to be told that no you cant have an engine with a broad powerband and linear power delivery without vtec, which you can.
most people dont get me
But you are using an engine which has variable valve timing to prove your point, doesnt that kind of undermine what you are trying to say?
no, its just another way of acheiveing a similar result, my point entirely. You could forget vvti and use more displacement if you wanted.
Can you show me an NA OEM engine that makes 100bhp/litre without variable cam timing/lift or a variant of such.
entirely possible but the cams would be so wild it wouldn't idle and would be choked at low rpm.
Thanks for the lesson unrelated to my question.
Keep that stock of straws nice and high for your many egg sucking sessions.
