Samsung NC10
Sweet. Well ive decided to buy one from work :cool:
Anybody recommendations on an Antivirus for the thing? Currently have 1 more license left with Kaspersky however i can get Eset products for cheap so wondering if that's any better for the Atom.
My experience with Kaspersky on an Eee box (same Atom CPU) was not good. It slowed things down especially IPlayer. In the end I opted for the free Avira AntiVir which doesn't impact on anything I run.
Just my 2 pence worth.
Martin
Martin
Does AVG have the same impact slowing the Atom down on the Samsung NC10?
Also, any more pics of the black version?
Ta
got kaspersky here and doesn't seem to effect things too much, just the annoying pop-ups when i install a new program or something....
just a heads up, found a piece of software today called "dropbox". basically an online storage (2gb i think) which you can set your desktop and laptop to synch to, so if like me working on a laptop and on a desktop then whenever i make changes on say the laptop, then it will appear as it did on the laptop on the desktop when i decide to work on it on my desktop. You do need to be connected to the internet to work, but as i use the laptop mainly at uni or at home this isn't a problem. Similar to MS Foldershare, but for that both computers need to be on at the same time, and has no online storage
I have the white one and im using AVG. It runs flawlessly and doesnt slow anything down.
I can't understand why they made the black one glossy and the white one a matt finish.
Because they are Dumb !...I think Glossy black plastic looks cheap, reflects and shows up everything and then because It has to be constantly cleaned, picks up scratches
Mine isn't really glossy, kind of like a satin finish, but i wouldn't call it glossy. Slightly rough to the touch.
You must have a different white one to me then mate. Mines the same type of finish you get on a samsung tele frame. The one on the black looks like the finish you get on the panel. The clear glossy look.
Mine must be different then, because it is not the same finish as my samsung tv. Strange. :confused:
