Easyriders Cinema Room
If you google Sub placement, you will find lots of technical information..... Once I saw an online calculator, can't find it again though....:(
The lad is only 19 as well. Not everyone has the money or space so you make do with what you have.
Hence the placques and my reason to explain their tackyness or indeed users immaturity pehaps.
Cheesy, would you stick a Ferrari Sticker on a Ferrari?
Look forward to seeing more of the project.
How are you wiring the TV? socket behind the TV, or channelling into a switched spur? One thing I can't get my head around for when I do my room next year is sub placement. Technically you should site the sub once the room is finished, but then it makes it harder to hide sub cables.
I have made a channel in the main wall
All wiring will be behind skirting unseen.
I take it that the TV power lead is going down that trunking then or is the double box having a socket outlet fitted to it?
thanks but my issue is when I do it. can't imagine working out out where sub sounds best in a half-finished empty room is ideal.
The double socket in the picture is for the HDMI lead. I assume the TV will be plugged into one of the double sockets at floor level?, although I would personally put a fused spur next the double socket and wire the TV into that, that way having no visible cables.
The Power lead and coax and audio cable and HDMI will be going down the trunking.
I will fit one of these over the double gang box
An awesome thread,
Ill be watching this, i really hope it comes out how you want it. I couldn't think of anything better in a house than a cinema room :D
Good luck
Best thread in ages......
One complaint though, I would like more pictures and updates:p.
I've been off work since the thread started waiting for a back op.
Great stuff Easy!
i thought it would be some new pictures here today... I'm a bit disepointed actully, I love this prodject and if were possible I would like a 24/7 streaming vidiolink to this prodject! that would be awsome!
