how do you add friends in the game? shall we get an ocuk freind list started - start some ocuk online games?
also is it possible to have custom soundtracks - like in gta 4? i.e. the game reads mp3's from my computer?
You're not meant to, I don't think, it's sent out to the other people online. The music will mute for them everytime you 'say' something, So try to disable/mute it when you're not using it, as it does get quite annoying only hearing someone elses background noise. I think it's to cancel echo, perhaps.
It will show the speaker icon for your name when it picks up noise from your mike.
Really am loving this game so far, just wish they had included the crash modes from the previous Burnout's..!!![]()
Anyone have any idea how to get double monitors working on Vista? I did some searching and apparently for some reason Microsoft took out Vistas ability to do horizontal span over more than one monitor, so you pretty much can't do it, end of.
It'd be handy to be able to just have the map on my 2nd monitor to be honest..
It better do, MS would be stupid not to include it this time. I probably won't upgrade to 7 for a while since I got vista soon after release.that'd be awesome
I haven't tried it, as I don't have a second montitor, but horizontal spanning may work in Windows 7?
just about to download the demo, think this will run ok on my spec?
OK, downloaded the demo and it's everything I expected from a Burnout game, but with one problem... my gamepads don't work with it!I tried both a Thrustmaster pad designed for the PC and a DualShock2 with a PS2 pad with a Dualshock-to-USB adapter. XP recognised them both, I tried them in a couple of different USB ports, I plugged them in before launching the game, but still no joy!
Has anyone gotten this to work with anything apart from a 360 pad?
