Don't the 2.2 engines have problems? It is better than the K series engines but if you buy a Toyota powered Elise then it won't keep up. My turbo dooesn't surge all that badly, not compared to previous cars i've driven, but yes it does have lag and needs to be in the right gear for the right speed - ie) no torque whatsoever below 2,000rpm...but then again I don't drive it slowly, so never been bothered about economy.
if you're looking at the S2000, take a look at the DC5 too, has rear seats, so a bit more practical
Hes looking at a two seater rear wheel drive convertable and you recommend a DC5?
Hi im looking at buying a Fiesta, how about an icecream cone instead sir?
Are they practical as "my only car" kinda car.
Also, what other suggestions do people have? Doesn't have to be a soft top, but I don't want a tank. As you can tell I don't know much about cars
I wasn't that impressed with the Toyota powered Elise in terms of the engine, it has less torque than the VX does. The Toyo engines as I understand it also have some reliability issues.
No, they're pretty much bullet proof. A minor issue with a revised oil jet for the timing chain is the only problem I have ever heard of. The engine should go on for ever really without any problems.
Dogbreath - Yeah I'm aware it is heavier, how does it compare to the weight of the Toyo engine?
This.
Either car as a first car is liable to kill you. I would seriously not recommend a RWD sportscar to someone as their first car.
10:1 you'll feel differently in 1 months time.
18 months? Are you serious?
Come on, anything could change by then, its not even worth thinking about
Personally I dont think the S2000 is twitchy, I think it is an excuse for people who crash them.
I drive a 2000 model too which is the most severe.
As for car choice, I considered both. I saw the S2000 as a car, the VX220 was just a fancy go kart.
