Surely turning the case upside down would have turned the radiator upside down too?
This is getting more and more bizarre. We now have a £60 cooler with a heat-source directly above the CPU (the pump) and a single, thin, 120mm radiator that is outperforming custom systems costing 8 times as much with 6 times the heat dissapation area? It does seem just a bit too good to be true.
Anyway, I have ordered one from a competitor that has plenty of stock and it will be here on Tuesday. And I've ordered a NorthQ Siberian Tiger from the same source as well. Oddly, they've not seen a big rush on either of these units and there's no big fuss about these on other forums.
And if you turn it upside down, it improve the performance by approximately 8%. That would suggest there's air in it to me.
im thinking of getting a H50, im currently using a Fenrir and have temps of 80-90 when using prime for 1hr or so.
im running my i7 at 4ghz with 1.3V.
Very interesting thread so far
Will the H50 cool my i7 better or not?
without a doubt, I had a Fenrir and they are not very good at all.
@bulldog &Gaidin, those temps are amazing, 67c @ 4GHz is awesome imo..
I'm a bit worried about spending £300+ on a custom loop now incase it doesn't perform as well as these units...
i7's tend to generate a pretty high amount of heat, certainly more than i ever experienced on my air cooled q6600 at 3.8ghz.
I have to give my hat off to Gaidin, as he is 100% right to try to turn upside down H50 rad and were shocked myself how low temperature are ! Best to blow hot air to the back of exhaust, many thanks Gaidin.I use push-pull same as Gaiden. We both had the same compare on the H50. (probably to do with us both as a lucky cherry cpu chip)
lol I always thought newer = cooler ... i7 hotter than q6600![]()
So whats the best way to install this?
Everything upside down and exhausting the air out of the case in a push pull config?
The I7 is a lot hotter thant the quads or core2s. Memory controller and HT adds to the heat.
It seems in mine that having the pump upside down makes it work better, god know why! I dont think it matters about the rad. I have two apache fans running at 1300rpm exhausting out of the rear of the case, so the are drawing air from inside the case. although I have a fan in the front of my HAF932 which blows cool air directly from the front to the back.
So members who have this already, did you use the thermal paste that was already on the base of the H50, or do you remove it and apply your own thermal paste?
