So how come it's like that seconds after him first turning it on?
He turned it back on immediately after powering down... mine sounds the same
I can get this for £220 including quidco... so close to my £200 budget!
It's either this or a Madcatz TE which I'll dual mod when I get my first pay cheque, although I should be able to get a slim for less than £200 nearer to Christmas.
just been reading some of the previous posts regarding deactivating the ps3 , i just need some one to clarify something
i have a 320 hd in my 60gb phat ps3 ,do i deactivate the 320hd or do i put the 60hd back in and deactivate that one . , will be trading in my phat for a slim on sunday
thanks
Anyone else think the slim installs demos and games etc. much faster?
I think i read you can now sync the PS3 up with Bravia TV's so would i beable to use my TV remote to operate Blu Ray's without the need to buy a dedicated remote?
I was downloading content whilst installing, which is normally slower, but seemed very fast.
rp2000
PS3 (obviously), sixaxis pad (DS3 would be fine too i'm sure), composite cable, ethernet cable.
Just an update,yes you can navigate blu ray movies via your bravia tv remote.
