A lot of SE types **** me off, with worrying about very small detail
My degree is: BSc (Hons) Software Engineering. So I can tell you precisely what the difference is between computer science and software engineering is.
Mechanical Engineering, Civil Engineering.
All other engineering subjects aren't really engineering
Riiiiiggggghhhhtttttttttt
The only difference I've ever found between SE grads vs CS grads is the later seem a little less easy to integrate into projects straight from uni.
A lot of SE types **** me off, with worrying about very small detail, causing massive delays in projects when it could have been done to the same standard they're advocating if they just stopped having meetings to discuss user case documents and actually did their bloody job![]()
Oil does look good fun. I'm sure there was a guy on here who posted regular updates and at one stage had to light some waste burning/flue with a shotgun of sorts. 2/3 weeks on then 2 weeks off sounds great![]()
Not with a relationship or young family. It's got a seriously high rate of family relationship problems.
[TW]Fox;14885857 said:If you were an engineer you'd be earning a lot more money, so I think thats case closed. Job title engineering for the lose![]()
Neither are actual engineering really though are they?
Unless you're a mechanical Engineer of the Matrix?
I could throw a spanner at the largest mobile network on earth - will that do?
I agree, engineering belittles a lot of the work of software creation. About the only thing that's more complex is the human body.
Well I know people that could alter part of a vaccine that goes out to millions of people, potentially killing them. They're not enginners.I could throw a spanner at the largest mobile network on earth - will that do?
No, that would be a terrorist.
Who designed the rocket to put the satellites in space that form part of the telephone communication system before Bill Gates got near anything like that.
you don't happen to work for Cap do you amiga? Either that or Fuji I reckon!
If so, get out, move on!![]()
No, by the sounds of it, he works for HP but came in under the Image acquisition
+ aerospace, general (cambridge) & electrical.
Software is not a pure engineering disapline.
