Higher res nicethose stickers definatly look better than those crappy girl ones indeed.
definatly not photoshopped as not only that those images are displayed directly on XFX website.
"you require one panel with a DisplayPort connector"
PLEASE tell me there is an Display port to DVI converter so i can use my 3 screen??!
This has probably already been mentioned loads but the port arrangement on the back seems really poor to me, the air is focused to come out of a small space which is surely going to make it noisy. It makes much more sense to me to have the two dvi ports on the bottom (with the card resting on a table, pcb on the bottom) and the two display ports vertical, one above the other. The vent could be almost twice the size then.
I would expect that it didn't matter to be honest.
The air would just come out faster out of the smaller vent, aka venturi effect.
The same volume of air would pass through, it would just mean the smaller vent has less air coming through faster due to the narrower passage, the wider vent would have more air coming out slower.
Bundled with Dirt 2 DX11 game.![]()
Why do I get the sudden feeling that we're gonna see vouchers appearing in the boxes of DX11 graphics cards to claim your free copy of Dirt 2 when it finally arrives?..
What? There is actually a directx11 game available for directx11 launch, what madness is that!
I still havent seen an answer for it, but are those red bits at the end exhausting or vacuuming air? I hope its sucking in air.
