- 18 Oct 2002
How about the "Apple Mini DisplayPort to HDMI adapter cable by Neet® - ( for Unibody MacBook - Pro - Air etc. )"
This is only £14.95 and as it's an Apple compatible, should be active right?
Then you just need a few quid HDMI-DVI cable and away you go.
No, that won't work.
It needs to be active (i.e. powered, generally from a USB). They are usually ~£75.
, that would be an awesome setup!
