I'm sure it just needs the right bios.
This. MSI have already said they will be posting their bios up soon which allows higher speeds in CCC and voltage mods.
Surely they would only allow this for MSI customers though??
Nope. They posted up the modded 5870 bios for all to download and have stated the modded 5850 bios will be up for download soon.
Depends whether you want to flash your 5850 card with another manufacturer's bios tbh.
My old koolance low profile one been using it for my last few cards still serves me well. I know theres better out there but it still cools a dam site better than any air cooled solution, plus I dont have to keep buying new ones for each card. Just home from work now I swear I'll never get round to benchmarking this thing properly till next week at this rate! Bit worried about my VRM temps though, even though I've put heatsinks on them still seem kinda hot when running furmark (80s) in everest though when gaming only in the low 60s is this OK? Can someone else with the stock cooler still on tell me what everest is saying for you when running furmark/gaming think i'm gunna beef up the cooling on them.
That is what I'm not keen on doing because that would screw any chances of warranty, I'm happy with my 800/1200 overclock atm![]()
but maybe msi bios may not work on other brands?
powerplay works perfectly on my 5850.So you can't use powerplay at all then?
If there are some that don't have this issue (which I'm guessing there must be), what's the link between those that do?
Powerplay works, but with powerplay on(maybe only in win 7 64bit, and 32bit maybe) it causes the mouse cursor to get huge, and high def playback causes the gpu to shoot to 99% load(even though surprisingly temps don't increase at all) and completely unresponsive desktop requiring a restart to get back to normal.
Since using gpu clock tool, I've now played back 2 vids that previously cause the issue, and no sign of the mysterious and strange large mouse. Same fix has worked for a bunch of people.
Hopefully it won't be there in final release drivers, theres a RC7 for anyone that wants it available direct from MSI's site(link on product page for the 5800's), though apparently has the same problem and no differences anyones noted as of yet.
It could be possible that, well we've see the UVD voltage is changeable as MSI afterburner can change that, I could be wrong but thought the UVD was responsible for video acceleration, so maybe powerplay at the moment is incorrectly dropping voltage to idle, and becomes unstable during high def vid playback because the main core clocks/voltage remain low, and the UVD isn't stable under full load at a reduced voltage? THat would certainly explain it the high def problem, not sure about the mouse cursor but thats also fixed without powerplay.
WHen I'm not using high def vid, powerplay works fine, I get nice low power usage and its stable and I can game fine, just when I playback vid.
Hmm, though saying that, I don't think i've seen speeds as you get in state 3, I haven't seen 400/900mhz at all, so yes, thats probably the issue and some combo of high def is unstable without the clocks/voltage available at the higher clocks.
Gareth, have you tried watching any mkv encoded files, 720/1080 stuff, it would crash for me(or be unresponsive) when using WMP, VLC, MPC. But it might be certain types of video.
