Hello I am experiencing severe problems with my Sapphire ATI Radeon HD 5850
and would like to know if anyone can help.
First- boots bios and displays windows after install.
The issue is when I install any driver version, first i tried the supplied drivers from the dvd that came with the card. Installs fine, but upon restart system becomes toally unresponsive and there are graphical glitches present everywhere which were not there before install, running anything is out of the question. Same response from Vista SP2 & Windows 7 (Build 7600)(From freshly formatted installs).
Then I tried the recommended drivers from ATI 8.66RC6, again installs fine logs says its ok. But upon restart the screen goes blank after the windows loading screen and stays blank(Left for half an hour), (The same response in Vista & Windows 7) I can only restore from safe mode but the drivers are then lost. I also tried 8.66RC7 with the exact same results.
I also tried intalling the supplied drivers & then just updating the display adapter from recommended 8.66RC6 at which point the screen imediately goes blank(Again left for 30mins), even after restart it is still blank.
The only options I can think of are wait for official cata 9.10 ib the hope that it works or return it as i can't do anything with it right now. Any help is much appreciated. Thanks.
Incase this makes a difference heres the Details:
Motherboard: Asus P6T SE
Motherboard Driver: Rev.406.03 (From DVD supplied)
Motherboard Chipset: X58
Motherboard BIOS: 0504
CPU: Intel Core i7 920
Memory: G.Skill Trident 6GB (3x2GB) DDR3 PC3-16000C9 2000MHz
Memory Latency: CL9T
PSU: OCZ ModXStream Pro 700w
Graphics: Sapphire ATI Radeon HD 5850
Graphics Driver: 13-009(From DVD supplied) also tried 8.66RC6 & 8.66RC7 From Ati website
Operating system: Vista SP2, Windows 7
