Windows 7 installed in under 6 minutes (using a USB drive but still)A total of 9 minutes including the following reboots, set up stage (name, CD key, network, etc) and performance evaluation.
9 minutes to install windows 7 - LOL - what kind of DVD drive you got? It takes about 10 to copy and uncompress files of the dvd rom
how did you get win7 to install from usb?
Something is seriosuly not right with my results now after the update to my 128gb.
Can't see wiper helping that much. Looks pretty bad, I'd be inclined to reinstall the drivers and if that fails flash it again.
You'll likely have to run wiper if it supports the crucial drives after the firmware update.
What an utter pita that was getting from 1711 to 1819. It works though.
- Boot from Windows 7 install IDE mode on another drive, UAC off.
- Backup M225 install with Acronis Home 9, Bit for Bit, free space and signature selected.
- Delete the M225 partition, run CTXXXM225_1571.exe
- Select the right disk and run, wait an age and panic it's hung.
- All ok back to 1571, reboot from USB disk with CT128M.exe and install 1819.
- Restore Acronis image and check partition is 1024MB offset.
I'm in two minds whether to enable TRIM or not, I'll leave it for now.
fsutil behavior query disabledeletenotify , 1 means TRIM is off.
fsutil behavior set disabledeletenotify 0 , would turn it back on.
Here you go my good man.
