What fan did you replace it with? I've got my eye on something like the Akasa Apache, but wondering what other quiet options there are with good static pressure. Currently I've got the Corsair fan running at around 900rpm using speedfan which should tide me over.
Anyone fixed one up in an Akasa Eclipse case? I`m thinking about about leaving the rear akasa fan in place (as exhaust) but replacing two of the screws with two of the longer screws that came with the H50 to secure the radiator in place to the akasa fan, and then attaching the CPU temp controlled fan that came with the H50 on top of the radiator again acting as exhaust so forcing air through the radiator. So the akasa fan will be pulling air through the radiator at max speed while the H50 fan will be pushing air through the radiator from the inside at variable speed. The H50 fan will have to be variable speed though depending on the CPU temp although my bios does allow a target temp to be set (min is 40degrees I think) at which point I assume the fan will come on full speed.
Sound okay? Or should I reverse the fans around? (so the CPU temp controlled H50 fan is attached to the chassis acting as exhaust pulling air through the rad and the akasa is pusing air onto the radiator on max speed. Hmmm, think I`ll try the first method first
Anything that uses mis-matched fans (speed or air pressure) is very unlikely to work well.
You want two matched fans that are both running at the same speed.
One reason the Apaches work so well in push/pull combinations is that they are PWM and you can drive two off the CPU fan header with an Akasa PWM splitter cable. That gives near silence at idle and they ramp up together when the CPU temperature picks up.
I'm thinking of building a new PC and these seem interesting. A forum member mentioned one of these in my spec thread in general hardware, and I've never done anything like this before. I do have a few questions if that's okay:
1) Do these have to be refilled with water on regular basis.
2) I'm thinking of getting a antec 902 case. Do these fit well in it, and do I need to purchase any additional fans?
3) Are they more quiet than a Noctua fan?
4) Do all parts i.e screws etc come with the h50?
5) Does thermal compound come with it, or best of getting m-3 compound?
I'm not to keen on the buzzing sound, so I may stick with the Noctua fan idea.
