snip
I'm now doing 2x dual core SMP folding VMs for OcUK on a i7 920.
I presume that means my q6600 is scoring significantly too low for some reason?
And, by the way, does it score continuously (although updating only every hour/three hours) or does it score only when you complete a work unit? I presume the latter?
Now is it just me or do the WU's come in pairs because i Have two 1888's come in @ the same time and it's bloody annoying me![]()
Is it running in SMP mode, or the standard Gromacs? Post up a shot of processes in task manager.
looks like you're using the regular single cpu cores. You'll get better ppd with the smp client, which on windows is a bit tricky to set up. You'll get even more ppd on a linux machine or a linux vm (as a lot of the team do). The linux client is much easier to est up, but if you're a windows guy, then there's the hassle of setting up an unfamiliar OS.... although I think you can get pre-prepared appliance vms.snip
)looks like you're using the regular single cpu cores. You'll get better ppd with the smp client, which on windows is a bit tricky to set up. You'll get even more ppd on a linux machine or a linux vm (as a lot of the team do). The linux client is much easier to est up, but if you're a windows guy, then there's the hassle of setting up an unfamiliar OS.... although I think you can get pre-prepared appliance vms.
There's a very good guide somewhere in these forums (might be one of he stickies)
Think this is the guide that Happy posted a few pages back good guide on how to setup a VM
http://www.ocforums.com/showpost.php?p=6061998&postcount=6
The SMP GUIDE can be found here.
*runs from OcUK*ATI i dont really know!
Ta for the ppd info above.
Because you only used to be able to use 2 cores in Vmware player. Now you can use 4 you can use one VM and save some RAM![]()
thanks.
