Generally you can take however many cores the Nvidia card has, times it by 5, and you'll roughly get an ATI equivalent.Looking at the specs and with previous comparisons i would reckon that the 360 will be slightly faster than the 5870.
assuming 58xx series hasn't created more efficient cores...Generally you can take however many cores the Nvidia card has, times it by 5, and you'll roughly get an ATI equivalent.
This makes the 360 around 1920 'ATI' shaders... So 20% faster than the 5870, assuming clock speeds are the same.
It's always been difficult to make performance conclusions from comparing NVIDIA and ATI specifications in the past, so I don't see why it would be any different now.
The problem is that it is theoretical performance and it will not mean a the ATI card is twice as fast.mhh 360 looks like it has twice less teraflops then 5870, would this impact the performance or it does not really matter as it using new architecture ?
But chances are them cards are fake....i cant believe you lot, here we have a picture of the Nvidia head of Marketing showing two of the new Nvidia cards and a list of specifications, and all you can talk about is the case thier housed in. laughing my bottom off
So am more interested in the case![]()
If nvidia really had two working GTX 380 cards and they were blowing ATI 5870 & 5970 away then nvidia would be leaking the scores all the internet..
I think they like to drop these little nuggets every once and a while to remind people that in the future a new Nvidia gfx will appear. It may be enough to sway those unsure about purchasing one of the 5xxx and think their effort will be appearing sooner so they hold off.![]()
Id love to know where the airflow is in this thing, if you go to the following link and enlage the pic theres a disturbing lack of fans on what is meant to be a pic of a fully built computer.
http://www.maingear.com/boutique/pc/ShowInfo.asp?SIArray=84,&cd=The Final Finesse
Cable managemets really nice i have to say, just where the hells the intakes?? I can see a spot for one at the bottom but that seems to be a dedicated fan for the hard drives.
If 360 is equivalent to a 5870 and priced competitively I think nvidia are onto a winner.
If 380 is equivalent or better than the 5970, ATi should be worried.
There are two 180mm fans for intake on the RV01-B (which does have the exact same internal chassis) inside that thick crossbar, one above the PSU and one under the HDD rack.
Wouldnt say its an excellent cooling solution but it did work pretty well.
