Will the Pulse be able to upgrade to Android 2.0 when it surfaces? 1.5 is nice but the Android platform is still in it's (relative) infancy, the more we can upgrade it the better
 I had seen a report that T Mobile in Holland will provide an upgrade to 2.0 but not sure when that will be (or if it will actually happen).
I've been using my Pulse as my main phone for a while and overall I like it. I've unlocked it for my O2 sim, put the December update on it, and then put the MoDaCo custom ROM on. Not sure if it runs much faster as I can't remember how it ran originally but I didn't have any problems with it then.
- The screen can sometimes be unresponsive round the edges
- The camera is quite bad (but I didn't buy it for that, so that's ok with me)
- Battery life is not great - lasts about 36 hours on very light use.
+ Asewome value (cost me £90!)
+ Easy to use
+ Android apps are great
+ Apart from the edges, the screen is quite good
There may be more significant negative points to the positive points, but for me the Android apps make the difference. I got this for £90 as a go-between phone until the Bravo comes out, and it's been well worth it for me. Before I got this, I couldn't decide between an iPhone and Android phone, but now the choice is clear.
Note - this is my first Android phone, so I can't compare the above points to other Android phones or the iPhone. My last phone was the N95 8Gb which I didn't like.
