http://img46.imageshack.us/img46/1299/latenightbasket.png[/QUOTE]
Would you not suggest the Club 3D which has the better spec and is cheapest??
[quote="reiyushin, post: 15800907"]Yes :)[/QUOTE]
Ok cool :)
[quote="Aleksandrs, post: 15800909"]I think for that sake its worth getting the cheaper one then, which means if you really wanna save a bit extra money you might as well get the 750w psu, as that can still easily take a crossfire setup (if you ever even get that far which I don't think you will as this is definitely powerful enough).[/QUOTE]
I've swapped out for the standard version, kept the 850watt as it's only £5 more :)
[USER=90501]@reiyushin[/USER] is that 'THE' recommended cooler at the mo? Looks ok..
Edit: beat me to the top bit :p
