Thanks nikaz, can't wait to see that, should be interesting to see the expert at work.
I've been advised (on another forum) to turn off the remainder of my assists, ie, abs, traction & stability. In which case, it's probably gonna put me out of this contest for a while until I can learn to tame the beast(s) unaided.
Yeah, when I record with fraps, the framerate drops considerably and take some getting used to.
Leave ABS on. The others only slow you down so you will probably improve no end after turning them off
Thanks!
