- 19 Jan 2009
The H50 was easy to fit and the hoses are very flexible. It uses 120mm fans and i'm sure it can be any 120mm fan but the cooler comes with one anyway.
well i tried to place a 650w gold seasonic and the intake on the case is in the wroung place its out by 25% so some of the fan is blocked not good at all as its a small size standard psu not the big ones.
also i dont know why they put a grill for the psu at the bottom of the case it would have been better to have a 120mm cut out as all psu`s have there own grill or some sort of protected grills built into the psu, this caused the case grills and psu grill to part block the intake as well so time i put my psu in the case there was about 50% blocked intake for the air not a good start at all.
i was not happy with the case and have had 2 the first was damaged becasue of the sound proofing coming of so went stright back the 2nd the top of the case had a bad finish where the top 2 fans sit if you look at it it looks like the screws that hold the blocking plates in place are bending the top of the case this makes me think the case is not very thick or strong and this was on both cases.
also the sound proofing was starting to come of at the top of the case, i dont think fractal are using strong glue and heat in the case could cause problems in the future as heat could make the glue shoft and make the sound proofing come of this seemed to happen on the 2 case i had. they need to use stronger glue
the 2nd problem is the cpu cut out does not support 100% of cpus and fractal are going to change this in the newer cases but to be honest it should have been done stright away its a new case not a 6 month old case.
the paint job is not good to as you remove the hd bays or any screws like on the psu all the paint comes of and you can see the shiny silver metal under the black paint now i dont know how good the paint will last over time on the outside but if its as thin on the outside as it is on the inside it could scratch very easy and that would not do.
the front door looks very nice but at close up its just plastic i thought the front door would be made of metal but it was not and there was no hd led or reset button i could have lived without a reset button but no hd led ? how much to add not much i bet.
the case does look nice but i think the build quality is not there, i might be Spoiled as the past 3 case i have had are antec but this might be a good case at this price point but for £20 more i am going for the antec p183 or the lian li b10 maybe as this is a lot of cash but if not it will be the p183.
a lot of people are happy with the case but i was not to many faults and design problems
just my thoughts which i would share, i have herd others having problems with the sound proofing comming of to and bad paint job so it was not just me.
its just not the case for me i like my components to last
thanks all
Was this the sort of problem you had:
Mine arrived today like this, the bitumen isn't lined up with the fan hole either. Really annoyed me as I was looking forward to making my new i5 build over the weekend and now I am having to start an RMA process and stare at a load of parts I can't use.
Wow thats really bad work there.
That is unfortunate. However, I think you're in the minority; the vast majority of us with this case seem to be extremely happy with it.
Having had direct contact with Fractal, I do believe they'll take note of these rare problems and address them however necessary.![]()
