a lot of people slating Clear Sky on hereI thought it was a great game as was the first,currently playing through the first again with the 2009 mod,will get hold of Pripyat afterwards.
I'd like to see you drink 3 bottles of vodka in 30 seconds and remain concious![]()
http://stalker.filefront.com/file/Terrain_Pack;94510
vastly improves the ground textures.
It's a clear sky mod but it works in CoP
I'm running that + the atmosfear mod
http://stalker.filefront.com/file/;110125
Which makes blowouts look amazing
Also it makes it so that on a clear day you can see for miles (no annoying fog of war)
http://img28.imageshack.us/img28/598/1101251.jpg
But thunder storms are awesome with it on![]()
Yes, version 1.6.02 is translated already, those packs are for the people that got the Russian releaseLooking around that sight I see there a lot of language packs for english. I assume my UK stalker will be completely translated to english already.
I also think the bandits speak English in the game but have I have only played for 20 minutes so I don't remember![]()
CoP seems a bit easy as well. The apparently tougher mutants like controllers and the fat dwarf things are easy if you just run up to them and repeatedly stab them. Chimera's can be tough but can't get through doorways so easy to exploit that.
Bloodsuckers seem to hit you once then run around. There aren't any that charge you and stay on you until you're dead apart from the mutant rat things and they are super weak.
I'm really struggling to get into it.
It just seems so aimless at times wandering around lost and dying randomly, I'd rather the emphasis be on fighting more.
that's because if they manage to get behind you they wrap themselves around your neck and you can;t move or fire while they hurt you.
Hi - have just downloaded these two. Quick question. what did you do to enable the groundtextures mod. I have just followed the readme instructions and it has created a folder called 'Gamedata' in my 'stalker call of pripyat' folder. Is that right?
edit - I see that the atmosfear mod has a gamedata folder within which a textures folder is found with two folders 'fx' and 'sky' are in. I guess I should just dump the groundtextures folder 'detail' in there then?
edit again - don't worry I think I have got it now.
Turn v sync on.
