So have no exhaust fan at all, just the radiator screwed to the back of my case with the Noctua exhausting into it?
edit - why would it matter, i have both plugged into the cpu header on a splitter so wont it lower them to the lowerst rpm of either fan at max?
If I use a Scythe Kaze Jyuni 1900RPM Slip Stream on the exhaust of the radiator (37.0 dB(A) at 1900 RPM, 110.3 CMF ) then have the Noctua NF-P12 sucking into the radiator from the inside of the case (19.8db at 1300 RPM, 54.31855 CFM)
Would the Scythe just lower its speed to 1300RPM? Why does it even matter if they are at different speeds, wouldnt the air just leave the case faster than its going into the radiator. Surely thats better, as long as its not the other way around and it cant expel hot air fast enough
I really do think that you are going to have problems using two different fans in push pull. They won't have the same throughput of air. You won't get a decent airflow. You'll probably get better results just using the single Noctua fan.
hi
noob question here. Just fitted one. Seems fine. Only pushing a new i5 750 to 3.2. Read through about 20 pages but no answer.
For the pump I used a molex to fan convertor. Instead of the suggested fan header.
My MB only has CPU and Sys fan headers. I wanted to keep front of case 120mm fan controllable.
Is this OK? The pump work all time anyway or is it ment to be controllable.
Then later on just buy another Noctua and use push/pull. As for running two different fans off the same header not sure whether they'd adjust to the same speeds or not, there voltage ratings might offer different speeds to each other, try researching it see if any ones tried/tested it.
. This will be handy when replacement gts250 comes back (for physx)the whole system is a bit louder, but not too much and the cooling is now much nicer
Might want to invest in a fan controller. Its what im doing when i get my H50, can have much better overclocking, noise and performance results when you can control fan speed. Rather than leaving it to the bios or 3rd party program to change the rpm depening on heat or whatever.![]()
im happy leaving the cpufan on the header but all the rest will be running of the controllerSo this kit just attaches to the CPU Bracket and to a 120mm Fan slot?
Sounds very simple.
I genuinely can't install mine!Planning on giving it another go on a fresh head.
how come?how come?
No idea! I think I've threaded the "things you put into the bracket with the clips" too much! Anyway, I shall update in the morning.
When it says turn screws one and half turns or something so its screwed in but not right in, you need to make sure they are very loose. I had one of mine so it was open. practice with no paste on first. I did this a few times before properly doing it. You need to press it right down then turn clockwise and it will lock ionto the threads
Did you put the paste on the cpu or on the h50 block? I usually put it on the cpu but just wondered if it made any difference.
I had planned on installing mine yesterday but my apache fans didn't turn up so I'll be doing it this week all at once.
