which 140mm fan did you get?
Another Fractal 140mm fan.
I'm replacing all of my Fractal Design 120mm and 140mm fans with some Xigmatek ones (silent, high cfm, blue fins with white LED). Will post pics when done ^^
What's the advantage of switching them out? They quieter and shift more air? The fractal ones seem pretty good to me.
Increased light = shorter shutter speed = less blur on moving thingsNot sure if the camera's flash stopped the case fans for a millisecond![]()
well it does on most compacts/auto modeAh really, more light effects the shutter speed? That is actually pretty interesting. To a camera newbie like myself anyway![]()
I think it has been mentioned elsewhere in the thread but if you have a 140mm fractual fan connected to the included fan control, and it's on it's lowest setting, you should check to see if it's spinning when you power up your PC. Sometimes it doesn't start up.
^ All of the white hard drive trays are individually removable. No screws or other fixtures, simply slide in and out.
