try some clearasil and use your own brush and soap.
also get your own towel for your face, preferably a newly washed on each time you shave
I use Taylor of Old Bond St aftershave balm.
As for irritation, get the method right and you will be fine:
1. Wash face with soap and hot water.
2. Apply foam, I find any foam works.
3. Using hot water to clear and heat the blade, shave 90 degrees to the direction of growth (never against the direction of growth).
4. Rinse using hot water.
5. Pad face dry with towel.
Interesting thread... was surprised to find this on a computer forum.
Could use some recommendations, currently use Liz Earle After-Shaving Moisturiser which is very nice, but a bit on the expensive side @ £16.50 for a 50ml tube, so can anybody recommend something similar but which is cheaper?
Thanks...
[FnG]magnolia;16124345 said:PRORASO pre shaving cream is perfect before and after the shave. It both preps the face and then afterwards closes the pores and protects the face. It's also incredibly cheap.
I don't think mankind stock it but a few of the UK online stores do.
Nobody?Does anyone know of any good shops/sites selling decent sized toiletry bags? I have quite a bit to take to the bathroom and it'd be nice to have a toiletry bag to carry it all in.
