Quite good! What size cards are people putting in? 2GB MicroSD TF cards are going for £4.22 on eBay so tempted to just buy one of those.
Mine bombed out todayBut managed to get a some nice on-bike footage of the commute to work, will get it uploaded. The camera is not being detected by the PC any more, and the LED is always on, you can't turn the unit off. Luck of the draw, will probably buy another one anyway!
Im using a 2gb, should be good for about 25-30 minutes of recording. Apparently it stops after 30 minutes anyway and you have to take a second recording. Either that or the battery will run out
Incorrect, they close @30minutes but it automatically creates a new file and continues to record.
With regards to the 30 minute limit:
Battery should be good for 2 full 30 minute recordings.![]()
A popular 4 letter website starting with P is selling 8GB micro SD cards for £9.99 delivered.
