Will be installing fan down. there's enough clearance at the bottom of the unit and it helps the cables be closer to mobo trayare you guys installing the PSU with fan down or fan up?
(looks like most people are installing fan down from the pics in this thread)
hey Demonmirc, where did you get that shelve from please?
I have received my case, and I am now starting my first ever build!
I could do with some advice with respect to fans.
I bought 2* fractal 140mm and 1 *sharkoon silent eagle 120mm
my plan is to put the two 140 in the top and the 120 sharkoon in the back.
i have already moved the rear fractal fan to the front, so i have two there now.
Does this seem like a good set up?
I am also unsure what direction/orientation I should have the fan cabling, for the rear fan and the two on the top?
can anyone help me on this - in particular I want to know what orientation my fan cabling should be pointing for the fans on the top and rear of the case.
Thank you for your reply gee.
I am sorry I was not very clear, I understand which way round the fans should be facing, what I was wondering about is what direction I should have the cabling for the fans emerging.
E.g for the fan on the back panel I could have the fan cable(wiring) emerging in the top left corner, the bottom left, the top right or the bootom right.
I know that there is not exactly a 'correct' answer for this, but I was curious what other people had done, and I want to know what is going to make things easy for me with respect to cable management.
my TX750 has enough space (atleast it looks like it does)If you want to put a 140mm fan in the bottom of the case, be careful as my PSU (Corsair HX750) is too long for one to fit using the included filter.
can anyone suggest best fans to get to go in this case alongside the 2 that come as standard I was thinking of getting an aditional 2 fans (1 Side and 1 Top)
