They are £9.99 delivered on the bay![]()
Nice, are these the official HTC cradles?
Nope you cant.
yes it is enabled
I only have the Magic but can't you add that contact to a group such as 'work email' and for your main contacts just in a group called 'contacts' or what ever.
When you search for a contact in exchange it finds them and you put a tick next to their name and click "Add". It then puts their name in the TO: box of the email. It adds them to your phone book though but doesn't prompt you for a group as far as I see. You only have the option to put a tick next to their name and click "Add". The addressbook thing is automatic from the looks of it. Happy to be proved wrong though but I've seen massive posts over at google and android forums about the whole searching in exchange thing. It's better than it was so they'll hopefully get there eventually!
Try installing Handcent - it's a far better SMS app generally plus it might sort out the notification vibration issue![]()
just tried handcent, when pressed 'test notification', it doesnt vibratesomething very wrong my desire i think
