so easy to burn through the best part of 15 quid!
Total noob here but i've just bought myself some nagas and bhut jolokia seeds... any tips from anyone? Got a nice windowsill to put them on but i'm thinking im going to have problems keeping them warm, should i get myself a heat pad to put under the propagator?
Also is it worth getting a grow lamp? if so any recommendations only after a small setup.
With Nagas/Jolokia you'll need to keep them in a stable temperature to stop them getting stressed. For germinating you'll need a good warm place (germinating doesn't require light) in a sealed box with some damp paper towels/soil.
Once they've germinated then you'll need to ensure they're in pots and in the sunlight. They'll remain sensitive to the cold until they've got their first set of leaves. Then slowly bring them into normal temps.
Grow lights (I'd recommend CFL rather than HPS/HiD) are good and will result in them having enough light but at the expense of 250W for a few hours or more each day (depending on how you use them).
Are they needed - well that depends on the weather and if you want to keep them fruiting when the days get shorter later in the season.
Both those varieties of chilli will grow over a meter high and two meter diameter canopy if you let them..
give wilko a try my local was selling healthy looking chilli plugs cheyenne and something else 5-8 leaves on each plugCALAMITY
My seedlings got to 3/4 inches so I potted them on into 3" pots and have been popping them outside during the day to harden off.
Forgot to bring them in last night (beer) and them rotten ******** slugs wiped the lot out despite the pots being up on a table. Totally consumed they were, only one had a couple of mm of stem left.
Back to square one now, not sure if they will get enough growing time to produce fruit now![]()
I try to be as organic as possible so I don't use salt or pellets,
Salt occurs naturally, using it shouldn't stop something being organic should it?
quite suprised because every other time i checked out the plugs in the vegetable rack they were all wilted/looking like they would be dead soon
if you leave any outside next time suround the pots with saltany slugs that touch it will melt/burst open
Cheers for the tips nickk!
So once propagated I can pot and put on the windowsill... sounds like a heated pad may be needed then, will a bog standard one do or is it best to get one that i can adjust the temp on?
