Finally received my GTX480 today
I have already installed it and have updated the drivers
In all honestly the card is not loud at all in normal use, In preparation I had already installed two 120mm fans in the base of my case as I got to thinking the heatsink on this card has such a massive surface area that fans could cool it very well
On idle as I type the GPU is at 41c and its been installed for around an hour.
I have played Battlefield Bad company 2 with everything on high and the temp did rise to 69c
I find this very lowactually cooler than my 260
I think my cheap fan solution is working well for me
The only thing I am not sure about is the temp system I am using to check is just OCCT, can anyone recommend a better free temp program I could try?
cheers
mrix
use msi afterburner with the on screen display for the temps
yeah it's kinda weird though with games and their temps, mines the same with battlefield i think the highest its ever got was 73c and thats with 3D enabled. where as other poorer looking games heat it up a lot more, i actually found a game yesterday that broke my 78c with 70% fan rule
gonna bodge myself in a fan aswell i think, the Scythe Kama Stay PCI Cooling Frame looks quite good to me
