This version will not be available anywhere else as its exclusive to GFWL as a digital download. Game is a fun mixture of aerial & ground combat this level is one of the best looking in the entire game
Game has a unique mixture of vertical & ground combat as well as some interesting mini games & pushes the UT3 engine in a different never before seen direction (similar to what BatmanAA did). Its technically solid & certainly a decent game with no bugs or obvious techncial issues whatsoever. Undemanding but easy to pick up & play
All screenies are 1920x1200 max everything + max PhysX + x16QA.
^ I was going to ask the same question - I assume that's GTAIV running with mods?
Also that WOW shot makes me want return. If only to see the world before the expansion changes everything.
DennisK4 - thanks for the video.
However is it me or does it run that slow/jerky?
Or is it the video compression?
And you took the words right out of my mouth as well about WoW
(I too thought it was a WoW shot, but is that certain?)
It does run somewhat jerky. It was recorded with FRAPS and that knocks about 10-15 frames off my fps.
Are you talking about the screenshot I posted? If so yeah it's WoW.![]()
