Thanks for that. Installed in about 30 seconds so quick![]()
No probs. It is much better than the HTC one. If only you could move pictures between albums.
Android by default doesn't do this, I've yet to find a collection of apps to replicate the function.
Using a Bluetooth headset on this phone is only good for receiving calls, which is a bit rubbish.
You need to get the Nexus car dock app and Voice Search app I'm sure there is a link in this thread somewhere
Having to bring mine into a Vodafone store store today to try and get it replaced. A spec of something has gotten behind the screen. The top right corner of the screen keeps popping up a little.
Khaaan! how well does the car holder suction to the dash instead of window screen?
Ta
Zaf
From what I can gather it's not too difficult and fairly safe - the biggest issue at present is that there aren't original network-branded ROM images available so you can't flash it "back". If you thus have a warranty issue you'll probably have trouble when you return it and they find you've flashed it.
Question going from the Orange ROM to a generic ROM ... do you have to reconfigure all of the settings afterwards (e.g. internet access point, voice mail number, etc) or is that information held in the settings on the SIM card?
Mine finally arrived from MPD this morning so should be waiting for me getting home from work tonight
Just need to get it up and running with some tune sand movies for the plane tomorrow. I take it if i call T-Mobile tonight they wont be able to transfer my old o2 number over in time?.... I have the PAC code ready.
Coming from Orange to T-Mobile took a day or so to transfer. I called on a Thursday and both sim's stopped working for an hour or so during the switch on the Friday
You have a point there. I've just cracked it open to see what is inside. It does use a proper DC-DC voltage converter chip (MC34063) which has an active current limit circuit and a max output switch current of 1.5A. It should be safe enough.I'd actually be bit wary of using that tbh, as the phone may well be trying to pull over 500mA if it's seeing it as an AC source. If the adapter really is cheap and nasty it might not have the necessary protection for this.
How's tmobile signal/3g signal in central brum?
hi,
anyone else having issues with shut down times..all fine yesterday, hadn't installed anything and its taken 15+mins to turn off.. from this morning i've also 'lost' the sound you get when you select something on screen..(its still ticked to make sound in my settings..) you can hear it very very softly if you really try to hear it right next to your ear in quiet room.. gutted, been great til now!
please help,thanks
I have the same one and its fine on the middle of the screen. I might get one of those stick on dash plates for satnavs.
