What is this Cell-Tech stuff I keep hearing about? Is it not just creatine? If so, why are people saying it's really bad?
Seen this in the store (American store) - even the yanks slate it. I wouldn't go there I believe it's full of crap.
I went to a gym once and the instructor basically told me that I could not gain a "thick body" so to speak. He might be right considering my body proportions, so maybe if I simply gain definition along with some mass that would be a compromise? All in all, I simply want to help peoples perception of myself. Lord knows I could do with a confidence boost sometimes
body stats: 6'2(around that, maybe slightly taller), 69kg, so as you can see, not a broad frame
I'll post a picture later so you can see what I mean.
You have the wrong attitude from the start, you need to be more positive about yourself. You are correct; you're limited by just having those dumbells but it isn't the be all and end all, there are loads of compound and core workouts you can do without any weights at all. Try exrx.net for a comprehensive list of workouts with and without dumb bells.
Hopefully I can inspire you by telling you that I am 6'3 and I weighed 67kg 3years ago. I now weigh 93kgs and am very happy with my muscle growth all by eating well and doing some really basic workouts! Can't you get to a gym though?
Best of luck fella, remember you won't get results in days, if you're serious you need patience and will power.
I'll try and get to a gym but its a real trek away and is expensive as hell.
What sort of improvements would expect to see by Oct(ish) and by next May?
I started traying last May at 58kg, was 63kg by October. There's some pics of myself from back then somewhere in the picture thread.
All I had was plastic sand filled weights, nice cheap Argos yokes. Got the job done.
Yes! Yes! Yes! Yes! Yes! Yes!
240kg Deadlift - in the bag baby! (Raw, no belts or straps).
That's me up to 600kg!
No vid unfortunately but SPW did witness it - I'll do it again with vid soon.
That is all.
You know the problem now though... you've gotta aim higher haha.
That is all.
Ah, thanks. Won't be touching that then.
Congrats FF. You've worked damn hard and deserve it. Such an inspiration.![]()
That is all.
Don't think that's going to keep me down! I'm coming to take away your position on that ladder![]()
Merci monsieur.Well done Freefaller.
