*** The all new iPhone 4 thread - Keep all iPhone 4 stuff in here ***
5 Jan 2004
right need some advice here lads. o2 aren't selling PAYG on thursday, i still have a preorder at apple but i wanted o2 for insurance purposes. So where is the best place I can insure my iphone. I was thinking halifax or barclays which would cost £12.50 or £5.00 respectively.
Any other recommandations?
,thxs
11 Sep 2008
,thxs
Can't you buy the apple insurance....or isnt that the same?
7 Nov 2008
Edinburgh, Scotland
I have a question about the Zagg Invisible Shield.
You have to spray a substance onto the film which is then applied to the screen.
Once dried and set on the screen, if you remove the film is there any residue left on the screen? i.e. Would you have to physically have to remove anything?
Or does it just remove with no residue?
Thanks.
5 Jan 2004
that just extends the warranty
Thanks.
its water you spray
