- 18 Oct 2002
- Theale, Berkshire
From China?
Thats a point, I wonder where the warehouse holding these thousand of devices actually is!
From China?
Unboxing video on Youtube - not sure if already posted
MacRumors up and running for me.
From China?
Not gunna watch the unboxingI want to be all excited when I open mine
Wonder if they come with the same crap headphones.
right need some advice here lads. o2 aren't selling PAYG on thursday, i still have a preorder at apple but i wanted o2 for insurance purposes. So where is the best place I can insure my iphone. I was thinking halifax or barclays which would cost £12.50 or £5.00 respectively.
Any other recommandations?
,thxs
Can't you buy the apple insurance....or isnt that the same?
I have a question about the Zagg Invisible Shield.
You have to spray a substance onto the film which is then applied to the screen.
Once dried and set on the screen, if you remove the film is there any residue left on the screen? i.e. Would you have to physically have to remove anything?
Or does it just remove with no residue?
Thanks.
its water you spray
