Post your mobile phone desktop!
[SKR]Phoenix;16835378 said:
Whats the issue? I just installed it and it worked fine. Then realised that to get the look I needed I had to buy it, but it's only 99p or something. Then you can skin it like my pics.
Keeps giving me errors that it can't connect to the server.
Updated!
Wall (adapted by me) / Launcher = LauncherPro / Widgets = yr.no Weather Forecast, Facebook + Twitter widgets modified by XDA.
Custom rom.
Is there a problem there, on the lock screen there are two different readings for the battery charge, the lock screen says 6 bars, the status bar says 5...
The lock screen battery circle is always filled IIRC, battery is 100% now though so will check again tomorrow.
Still cant get this to work.
followed a tutorial, ran the software, followed it like it said but it still didnt work :/
That looks pretty sweet, whats the battery status indicator at the top and the widget on the right hand side pic with all the switches?
Cheers! :D
Status bar is a custom ROM (Sparta) and the widget switches, see my appbrain sig link.
