thats a great first effort. much better than my first watercooling attempt.
can i haz ur job then plix.. seriously though, thanks for the approval, it means a lot to me
how are your temperatures?
my idle temp for the cpu is 39 , havent ran prime yet .. dunno how long to let the cooling "bed in" ?
after playing ten mins of bad company 2 , temps increased to 49/51.
gpu idles at 31, rises to around 48 max after 10 mins of bad company.
do these temps sound about right? not sure if ive tightened the cpu enough ?
has it made much of a difference?
does a bear sh .... hell yes, i used sit idle @ 45 , max was around 69/70
major difference in gpu cooling, almost halfed the temps .. i played bad company the other night , temps went to almost 80, ...havent seen it reach 50 on this setup yet.
you noticed much noise reduction?
yes, mainly becouse i dont need the fans even half way now, but i may get some of that dampening kit
GET CLOCKING!!!
Will be interesting to see what kind of clocks you can hit on your i7 now
All this watercooling talk is making me impatient! Wish I could start my build!Can i ask what fan controller are you using?
Looking very nice mateWill be interesting to see what kind of clocks you can hit on your i7 now
And get clocking that GPU!All this watercooling talk is making me impatient! Wish I could start my build!
Perry if you wanna know if temps are fine, run prime for 15 mins, to let it heat up, post screen shot of coretemp or realtemp. That way we can let you know, but from that set up i don't think u will have to worry about temps to much.
Congratz on the build, certainly looks nicer then mine, but i just went for cooling over looks, thank god i have no side window haha.
Looking good! One gripe, I know the plastic hoses were probably a bitch to fit but I just don't like seeing cable ties on them! Scares me! Go out and buy some thin jubilee clips. Would be safer and would probably look a lot nicer too! Get some gold ones! lol
Im guessing thats the max core temp, if so, nothing to worry about at all, especially considering you have the gpu in the loop too, those temps are excellent.
yea, those readings was from coretemp.
And don't worry about the overclocking part, you know we will help you with that when u recover from this.
OMG .. i hope you know what you are letting yourselves in for![]()
With reference to what you said earlier about " trainee " water-cooler, no longer a trainee, welcome to the club
stop it, you are making me blush again.
didnt try again since becouse i was not fully sure of the correct settings to try
ill tell you what,
if you want to bring it to the shop then i will clock it as high as it will go
ill need a few hours with it, but dont mind seeing as you have done such a good job
email my trust if you are interested
[will have to be after the end of the month as we are really busy at the moment]
WOW !!!
WOW !!!
...... email already sent, i really dont know what to say , im speechless !!.
thank you very very much,
..... do i get OCuk tea and biccies too![]()
