ohhhh thats bad...gareth, here's my Vdroop on the loose LOL
there're Vcore spikes even idling
ohhhh thats bad...
i've only ever had 1 motherboard that been like that, which was a asus board.
don't worry mate. most motherboard do that. if everything is stable it's fine.you just scared the **** out of me man. how bad is it? it's too late to RMA my mobo now. and yes, it's a freakin ASUS (see sig)
Hey saxon, can't you raise your north bridge a tad bit? I'm kind of spoiled by the 1090T and it's unlocked multies so not sure how you would that with a 1055T. upping HT and lowering RAM freq maybe?
Nice clock anyway and good to see you got your memory back to dual channel
.Yeah I can change the NB. However, I'm not sure how far my MB will take it? If you can tell me what my MB can take then I will try and raise it. I kept it under or around 2200 to be safe.
My memory is at about 1488mhz or something like that. I tried to get it to 1600 by lowering the multiplier to x10 and then raising the CPU Frequency, but it wouldn't boot, so I'm stuck at 1488mhz. Not to worry though, as it's seems fine as it is.
Will raising the NB have any benefits for me?
I'm not sure what the benefits of raising the NB are to be honest.
it improves memory & L3 cache performanceMy memory is at about 1488mhz or something like that. I tried to get it to 1600 by lowering the multiplier to x10 and then raising the CPU Frequency, but it wouldn't boot, so I'm stuck at 1488mhz. Not to worry though, as it's seems fine as it is.
if your using 1600mhz ram u need the CPU-NB to be atleast 2400mhz......
also is your ram voltage/timings set right?
So how good are these X6's?! Had a quick look around and you all seem to be getting a good OC on them. I am building a new system just now, whats the best Mobo/Ram combo to get the most out these new chips?
gigabyte 800 series board, 1600mhz ram
a 1090t should easyly do 4ghz. a 1055t is slightly harder.
i would change the motherboard to a Gigabyte GA-880GA-UD3H AMD 880G (Socket AM3) DDR3 Motherboard [GA-880GA-UD3H] due to no vdroop
do u mean integrated gpu? if so yesThat the one with the integrated chipset? If so that looks like a pretty good system.
If I was to stretch to the full £1000 would it be worthwhile going a bit futher on the Mobo? And also would you say the RAM is ok?
